Computer Shut-down time
awinto10
Post by awinto10 »
After using reolume 2.3, as with most of the other versions, my pc is taking a long time to shut down. This only happens after use of resolume.
I'm using the following spec
Athlon 2800+
1024 Mb RAM
128 GeForce4
200Gb SATA HD
Is this happening to other and is there anyway of solving the problem?
Andrew
VJ Nexus
Post by VJ Nexus »
Is your resolume shuting down properly? I noticed that sometimes after I close resolume, there is still a process running called resolume, that even if I manually try to end process it won't stop. This only happens for me in 2.3. This does cause my shutdown to slow a little bit, but nothing to complain about. For now I'm still using 2.2 until I can figure out if 2.3 is stable enough for me - as of now it's not, but maybe i just need to tweak more.
awinto10
Post by awinto10 »
I can see that any process is still running. Its not a problem at home but when using the program in clubs and the night finishes its annnoying having to wait for the pc to shut down, when all you want to do is pack up and go to the after party!!! (this has been the case with all versions of R2).
I've not used resolume 2.3 on a club night yet but i haven't had any problems with unstability at home. I'm using it this weekend (Sat night- see party announcements) for the first time so fingers crossed it will perform ok!!
