DXV Same as Source Preset impossible on Media Encoder CC
Zinim78
Post by Zinim78 »
Is this a known issue?
I can't create a preset for DXV to export same as source on Adobe Media Encoder CC.
I can do it manually from the Output tab when I'm when I have a file in the queue, but this only affect the size not the frame rate. And I can't even do it to the whole queue, for some reason it changes everything in the queue to the same size of the first clip I choose.
Am I missing something? Is there a fix on its way?
Thanks,
Nimrod.
Re: DXV Same as Source Preset impossible on Media Encoder CC
If you mean that Match source is not available for DXV3, we're working on that.
viewtopic.php?f=12&t=17980&p=72997&hili ... rce#p72997
If you change the export settings in AME for multiple items in the queue at once, then the properties for all the conversion items will be changed. That's how Adobe does things.
What you could to to make your life easier, would be to render your media to temporary files, then convert those files to DXV with Alley.
Zinim78
Post by Zinim78 »
Thanks...
I appreciate your responsiveness as always.
TioPablo
Post by TioPablo »
Thank you very much, we will wait for when the option is launched.
