Currently there are three choices for a shortcut to a clip.
- By position: The shortcut remains in its place, even if the order of the Layers is changed.
- This Clip : The shortcut is assigned to the CLIP.  If the clip changes places, the shortcut remains assigned.  If the clip is deleted, the shortcut is removed with.
- Selected Layer: The same shortcut is used for several Layers. According to the selected layer.
During my Mix, I often add adjustment Layers. That I sometimes change places.
I regularly move the Clips as well.
None of the proposed Types of shortcuts suit me.
By position: If I add a Layer between two Layers, the clip shortcuts are assigned to the clips of that Layer. When I don't want to.
This clip: If I move a clip, the shortcut moves with it.
I want shortcuts to be assigned to the Layer:
If I add a layer, or if I move one of them, the Shortcuts remain assigned to the same box.
If I change the clip, move it, or delete it, the shortcut is always assigned to the same box.
