navigate between columns with fader
moha20106
Post by moha20106 »
Hi all,
I'm trying to navigate between columns using the midi fader controller, but the results is bad, there's no fading
Example:
I was set the column 2 for fader 1 using midi shortcut
And the column 3 for fader 2
But there's no fading for output showing
I need to navigate between columns with fading,
How to do it?
He2neg
Re: navigate between columns with fader
Post by He2neg »
Coloms are just trigger points so either you click or not... for fading you ll need to take a look at transitions (mode & time) you find it on the left side of your clips...
https://resolume.com/support/en/layers
~Berlin~
moha20106
Post by moha20106 »
He2neg wrote: Wed Mar 27, 2019 10:27 Coloms are just trigger points so either you click or not... for fading you ll need to take a look at transitions (mode & time) you find it on the left side of your clips...
Dear He2neg
Thanks for your reply
You always helped me as well
I can't find the transitions option in arena
Can you please take a photo of its place?
He2neg
Post by He2neg »
Maybe its hidden... check the "View" Tap at the top and then check "layer transition controlles" ...
you can see multiple screenshots here :
https://resolume.com/support/en/layers#layer-transition
Transition
Transition
~Berlin~
moha20106
Post by moha20106 »
He2neg wrote: Thu Mar 28, 2019 10:59 Maybe its hidden... check the "View" Tap at the top and then check "layer transition controlles" ...
I got it, thanks dear very much
