Stupid question - old resolume arena (V4)
ypoubs
Post by ypoubs »
Hi there,
i'm still using my old resolume arena V4 and it works fine for what i need to do on stage (video projection for theater).
But i'm still looking for a simple shotcut : play next column !
i know that i can assign any key to play a column, but i'm looking for one key to press to play the columns in the order : like "spacebar". SO when i run a show, i only have to press the "spacebar" and resolume play the next column.
any idea ?
thanks in advance for your reply
He2neg
Re: Stupid question - old resolume arena (V4)
Post by He2neg »
I think you will need to use a workaround for that task in older resolume versions.... OSC is a possible way to reach what you need to do.
There is a OSC Programm allready from Resolume Team Member Zlotan (you can buy it)
http://palffyzoltan.hu/?url=controller&src=signature
For your Simple task you also can buy TouchOSC and programm it yourselfe. Then place an iPad next to your System and use this to have a simple "next" button for clicking the live show...
~Berlin~
ypoubs
Post by ypoubs »
first i do apologize for this late reply.
Thanks for your help and your advices, i think i will stay with "clic mouse button solution" or upgrade my resolume.
