Im a novice :-)
Anonymous
Im a novice :-)
Post by Anonymous »
Hi im raduZ. (.:R/I)!_!Z:.)
Im a novice in resolume.
Please Help.
I need to connect Live Camera through Resolume.
I want to use classic video signal with 75ohm koaxial cable and cinch connectors.
Is it possible? I want to buy any cheap TV card with TVinput.
Can it be? I heard the Fire Wire cameras works.
I need to changing color channels and contrast through resolume in real time. Please give me advice!
And the second question is. If i will have the graphic card which have 3 monitors. How can i work with it?
I will have one monitor where i am working.
But if i will have any 2 other. How can i choose which visulalizations will go to the second monitor and which to the third monitor?
Sorry for my english. Im from Slovakia.
Thanx a lot
.:R/I)!_!Z:.
SuperficiaL
Post by SuperficiaL »
Hi
1: buy a cheap tv card and use that coax cable, its better to use wires with less Ohm but that one will work fine (ive used them also)
but if you will be using tv in via a pci card (or any card for that matter) be ready for frame drops because the processing will lean heavy on the processor. its better if u use much live cams to buy a videomixer in my oppinion.
2: if u use resolume u need a tv out and i havent heard of cards with 3 monitors and a tv out... theres a Matrox card (Parhelia) that has 3 monitors output but that doesnt have a tv out in that setup...
greetz SuperficiaL...
Anonymous
Post by Anonymous »
Thanks for your advice.
In the second part you sad that the card with 3monitors dont have TV out. But i think exist the connector reduction from VGA to Video.
:cool:
raduZ
SuperficiaL
i know but,
here
is another thread about that
SuperficiaL
Originally posted by SuperficiaL
but that doesnt have a tv out in That setup ...
