Using Matrox GPU to create 8 outputs
MediaHelmut
Post by MediaHelmut »
Hey guys! Did anybody ever managed 8 Projektors with one PC? I tried two Matrox C680, but I think like resolume described, its complicated with datarendering, down to motherboard, up to next card.
Maybe better using one c680 with extension Triple Head to go?
Would you recommed a complete other setting?
Greetings Helmut
Re: Using Matrox GPU to create 8 outputs
Not sure what type of projectors (HD?) you’re using but my recommendation would be to use a RTX 2080 card with 2 Datapath FX4
