Cant save Composition after upgrade to 6.1.3.
Jahawata
Post by Jahawata »
Cant save composition after upgrade to 6.1.3
Lost some saved shows to.
Do I do something wrong or is it a big?
Run on a MacBook pro 2017
Re: Cant save Composition after upgrade to 6.1.3.
Check the permissions for files and folders in the Documents/Resolume Arena 6 or Documents/Resolume Avenue 6 folder - whichever version you have, and make sure your user and Resolume is able to write to them.
If that doesn't help, try renaming the folder.
Resolume should re-create the folder with the correct permissions, and you should be able to save compositions again.
Upgrading Resolume 6 to a newer version won't touch your documents folder though, so losing the older compositions should not be possible.
Do you see the composition files for these missing ones on disk?
Did you revert to a previous Timemachine backup, or modified the content of the folders otherwise?
