How to switch between different scenes (Screen)
z56667895
Post by z56667895 »
In my stage performance, the scene position is different (using the projector)
I don't know if there is any function that is similar to cue.
Is cue1 is scene one
Cue2 is scene two
thanks 8-)
He2neg
Re: How to switch between different scenes (Screen)
Post by He2neg »
You can use SliceTransform on clip or layer Lvl for this....
Example:
Layer 1 ( Slice Transform to Slice 1,2,3) : All Clips in this layer will play on these Slices in the selected mode.
Layer 2 ( Slice Transform to Slice 4,5,6) : Alle Clips here will play on Slices 4-6 in the selected Mode
If you need to Mask a bigger video to these Slices you´ll need to work with 2 slices and inverted maskes in the advanced output.
You also can use the slice Transform on the clip lvl and use colom to trigger multiple clips.
i think you can reach everything you need with this...
~Berlin~
