Hi, i'm sorry for my english,
I need 6x 1920x1200 outs ! in: https://resolume.com/support/en/lots-of-outputs for Single computer with two GPUs, he said: Letting the operating system decide how to render also means that the OS decides what card is used for rendering. Most of the time, this will be the card that has the main monitor on it.
So when using the outputs of the other card, the texture is first rendered on the rendering card. It then has to be transferred down the PCIe lanes of the rendering card, via the motherboard, up the PCIe lanes of the other card, and then sent out the ports. This will always result in a performance hit. The more cards you add, the bigger this hit will be.
I need Hdbaset outputs but if i used for example 1 card rtx2080 ti with the control screen and a advoli http://www.advoli.com/ta6distance/ with 6 vp connected ? i don't need a realtime, live, but edge. The native resolution of the show is possible with 2 1920x1200. after more display is used because the vp is close. lens problem.
Thanks for your reply
6 Outs + control
Re: 6 Outs + control
you need to do some testings for this special case...
my way would be to get 4 Outputs of one Card...
1x Controlle
2x 1920x1080
1x 4k ( 4x 1920 x 1080)
Sry Didnt see that you need WUXga 1920x1200.... then this wont work....
To convert these Signals into HDBaseT you need some aditional hardware.
The Advolie Card looks very interessting and i would love to see some test results for it. So please be so kind and share your results here if you try with this card.
1x Controlle
2x 1920x1080
~Berlin~
~Berlin~
Hi and thanks,
Yes, the vp are very closed and i need a 16/10 for the outputs.
My problem is: if the first cards with the arena control make all the job (if y anderstand) and all vp are on a second card with all hdbaset outs, it's ok ? i need 6x 16/10 out but the composition is possible with 1920/2400 for example
You wont have any Problem with special resolutions and stuff...
~Berlin~
~Berlin~
ok thanks,
Perhaps is better to chose a amd first card for work with the Advoli (amd cards) ?
I've make a new test,
1 computer for make composition and 1 for make a soft edge with ndi connection. Here is work fine. What do you think of this solution?
Thanks, regards
Thanks, regards
when it works it works
sounds like a possible solid solution
~Berlin~
~Berlin~
Hi, i've make a first test of this soluce. All is fine. I make the soft edge with 1 screen control on a motherboard and 6x 1920-1200 on a advoli card. work fine but 14 fps.When i reboot without the control screen Arena reconize the 6 screen and work fine but take more 2 min for understand. Dangerous! and i don't know how make a better way for Arena.
Idea ?
Idea ?
the soluce is: activate the scling of gpu in the driver!
So. At the ed your setup is what? And how many layers and resolution you can run with how many fps?
Advoli...
Advoli...
~Berlin~
~Berlin~
