Virtual Screen as slice source doesn't work
elgarf
Post by elgarf »
Looks like Virtual Screen as slice source doesn't work in Arena 6.1.3 both on Mac & Win.
Re: Virtual Screen as slice source doesn't work
You sure?
Works for me on my mac.
elgarf
Post by elgarf »
Hmm, looks like it not work only with "Show Test Card".
Yes, the test card overrides all slice inputs.
elgarf
Post by elgarf »
Ok, but that's a bit confusing.
Try making a screenshot of the test card into your composition with Command+Shift+P, and use that, if you'd like to see what everything in the Advanced screen setup does.
elgarf
Post by elgarf »
I just will use my own test cards, thanks!
