APC40 MKii shortcut preset missing
joelung
Post by joelung »
Hi everyone,
I'm new to Resolume family, any help will be appreciated :)
I bought Arena 6 around 9 months ago, and also have a APC40MKii . I remember I can find a shortcut preset for APC40MKii and it works perfectly by that time. Then I haven’t touching it for a long time.
Yesterday when I open Arena 6 on my MacBook Pro, it said I haven’t login for 206 days , and I have to restart arena 6 while I have internet connection. So I do so , and the software itself works fine, but the APC40MKii is not responding . I saw it in the preference , MIDI column , set it as MIDI in and MIDI out. But when I go to the shortcut ->edit MIDI, I can’t find any shortcut preset for APC40MKii but only default , and the default setting needs me to setup the buttons one by one. I’m sure I had one shortcut preset that I can load into it with the whole APC40ii functional before, not sure if I found it online or it came with the arena 6 tho. Any idea where I can find the shortcut preset for APC40mkii ?Or maybe anyone can share your APC40MKii default preset? Thanks!
Joe
Re: APC40 MKii shortcut preset missing
You can find the original Midi shortcut presets in the Resolume application folder / Default / presets / shortcuts/ midi.
Close Resolume, and you can copy these over to the Documents/Resolume Arena 6/Shortcuts/Midi folder.
Then start up Resolume and you should be able to load the presets.
