Hello
suddenly Resolume is not saving anymore any key shortcut settings
that i set in. This has been VERY FRUSTRATING.
I have tried opening new sessions and the program seems to
keep the anomalous behavior spreading to any session that interact
with the original. Is there a way out of this bug?
thanks
r.y
Resolume not saving key shortcut settings
Re: Resolume not saving key shortcut settings
Does this happen for you after creating a new keyboard shortcut preset?
If you create a new one, does it get created on the disk in Documents/Resolume Arena/Shortcuts/keyboard ?
Do you also save your composition with the new shortcut preset file active?
