my system enviroment is the next one:
-toshiba satellite m30
-graphic card 9600/9700 ati radeon series
-ram 512 mb
-windows xp service pack 2
when i wanna run resolume my laptop is shutdown with a error in the graphic card. ati2advg!!
any suggestion? i have installed the last drivers.
happy vj'ing
problems with ati radeon 9600/9700 series
Alright anonyomous wonders...
The black screen cursor thing happens to me too, rarely. I presume this is a driver loading failure or something. Don't know what causes it but a quick reboot usually gets rid of it.
As for the blue screen ati2advg problem did you try completely unnstalling and reinstalling resolume and your ati drivers as suggested? If you did, say so.
Last guy, what do you mean it crashes 'even in lo res'? Be more specific, and is this actually when resolume is running or are you having the same problem as others?
Finally, ATI's own drivers are my preferred these days. They got much better recently.
i'm anon1 for general purposes...
my ati has two problems... crashing on shutdown, the screen turns into a white and colored lined mess and sometimes during playing larger files resolume hangs. I tend to think i need to reinstall everything on my computer and find the right catalyst driver suggested by the man above here but all of them seem to me to be unstable. But at the moment all versions of resolume crash on shutdown.
It's been quite a while since i last replyed but i appreciate all the info. I will keep everyone posted when i reinstall my system and find the problem.
For a while I was using an ATI AIW driving two projectors, along with an OEM version of an ATI PCI card (9600, I believe, from MadDog) for the user interface. Occasionally I'd run a third projector off the S-video port on the PCI card, for a total of 4 different feeds simultaneously. (As an aside, let's have a big round of applause for Resolume's multi-screen support.) The system was reasonably stable; that is, I'd have occasional crashes, but mainly when I did something stupid like attempt to load or browse a corrupted video file.
A few months ago I decided to replace the AIW with an older dual-port ATI card -- I thought it was a 9x00, but it turned out to be a 7600, if I remember correctly -- I had lying around. Immediately I began to have problems: crashes, occasional BSOD on boot-up, disappearing MIDI (which meant no ReAct an hour before my largest gig to date). An upgrade to ATI's latest and greatest had no effect.
The situation improved when I switched to the Omega drivers, but the system still wasn't stable. Finally, I uninstalled everything, rebooted in VGA mode, and ran DriverCleanerPro. I then reinstalled the latest version of the Omega drivers. So far [knock silicon], the system has been rock-solid.
I'm positive I have a more-modern card around here, somewhere, either an ATI 9x00 or some sort of nVidia; when I find it, I'll probably replace the 7x00 with the faster board. Until then, I'm pretty darn happy with my current rig.
DriverCleanerPro: http://www.drivercleaner.net
anon1 replies
Hi everyone,
It seems that installing the omega driver solves all my problems uptil now. I wil keep you posted on how things go...
