pleaseeee drag & drop items anywhere in the screen feature
desconocido
Post by desconocido »
hi folks,
fist of all, apologize me for my english... Im spaniard.
well, I like Resolume very very very much, but I miss some features:
1. drag & drop items anywhere in the projection screen
2. change the size of those items
3. being able to move them in 3D in the screen
4. stacking more layers than 3
5. being able to group those layers
5. a crossfader between groups of layers
I think Resolume doesnt have yet those features, but if they're possible with Resoulme or using any plugins, please tell it to me!!! I need them for my VJing style!
thxxx in advance! good job done with resolume, anyway! :D
greetings from Seville, Javier
continuity-B
Post by continuity-B »
Some good ideas there. Although some can be done with plugins, it would be good to have them built in and simpler to apply.
Bit like GridPro features if I'm not mistaken?
desconocido
well, those features are the Modul8 goals, at less for me...
VjSky
Post by VjSky »
Yeah, I realy think you should be able to drop an effect on the layer, becauce, sometimes, I have to browse through many decks to find the clip that is in active layer. Also Zoom should be added by default, so u can combine zoom and some other effect on a single clip.
