Hiya I am new to this thing, I am trying to load in Visuals onto 2.3 but it wont let me load WMA or Quicktime, what files will work and how cld I covert them ? what file type would I need to covert them to please please someone help
Cheers
HELP WITH LOADING FILES
from the MANUAL
also FROM THE MANUALOpen the files tab in the interface and browse your hard drive for files that you would like to use. You can load the following media types. Movies:avi, mov, qt, mpg, mpeg. Flash:swf. or Pictures:bmp, psd, gif, jpg, jpeg, wmf. Drag one or more files to one of the channels in the middle. If you drag more than one movie or flash files, each file is inserted in a new channel. If you drag more than one picture files to a channel, a picture sequence is created in that channel. Activating that channel will play all the inserted picture files as an animation.
as for converting files, google it or search the forum, a lot's been written on this. Sorry if this sounds rude but we're beginning to get the SAME questions over and over.Although resolume plays mpg and mov files, for the best playback result of movies you should use the avi file format encoded with the Cinepak, Indeo or MJPEG codec.
Export settings:
Codec: Cinepak, Indeo 5.1 or MJPEG
Audio: disabled
Key frame every 1 frame
Quality: 100%
Resolution: 400x300
If the source footage is larger then 400x300
Deinterlace: on
Better resize: on
You should render every frame a keyframe if you want to play your files backward or if you do a lot of scratching. Rendering every frame a key frame reduces seek time so that the forwards and backwards playback speed is the same and that scratching will be faster.
