R6 - Nvidia 2080 geforce rtx
pette
Post by pette »
when I start some video in R6 in my new laptop (Asus Rog Gx531GX) the Nvidia CPU 3D process is up 85% play only 1 clip.
Even if I stop the clip the gpu is up to 85%.
What's the problem?
The Nvidia drivers are updated!
thanks
Re: R6 - Nvidia 2080 geforce rtx
Do you have an output display connected?
If you enable Show display info in the Output menu, does your the text on your external output say the same for the Renderer and GFX card?
Power options set to high performance?
pette
Post by pette »
yes
yes
yes
Do you see the same GPU load with a new empty composition?
pette
Post by pette »
I try with the example composition too
Vsync set to On, OFF, adaptive or half?
