Inserting USB causes V opacity to drop on all layers
Admud
Post by Admud »
Hey guys
As title says: weird issue whenever I plug a usb into front ports on server.
Also happens when removing USB
Happens on front and rear USB ports
Only happens on 1 server, doesnt occur on laptop or 2nd server...
Que?
Re: Inserting USB causes V opacity to drop on all layers
Sounds like you have some midi device attached to the computer and enabled in the Resolume preferences, and when you insert your USB disk, Resolume syncs to the devices, to check if you inserted a midi device which needs to be used.
I guess you have some midi shortcut mapping set up to the Video opacities right?
Admud
Post by Admud »
Interesting.
I HAVE had a midi controller plugged in previously, but not when I found this fault.
Res currently sees no Midi devices and yes there are midi shortcuts still enabled for opacity.
Changing the midi preset to APC40 default fixes the issue.
Weird that it does it even though there are no other midi devices available.
Thanks Zoltan!
Weird indeed.
The APC40 preset has channels assigned to the Master fader, to they keep their position now?
