Advanced output automatically
gavin
Post by gavin »
Hi all,
First time poster here - have done a decent search but no luck.
We have a large setup with blended projectors, and so we use Advanced output for our compositions.
I'm sure it used to automatically output when we opened Arena 6, but no longer does this.
Just after some help getting it to automatically output to Advanced as soon as the composition is opened.
Thanks heaps!
Cheers,
Gavin
Re: Advanced output automatically
If you close Resolume, it should store the current output config, and load it on the next startup.
If you start Resolume with the outputs not being connected to the machine, you'll need to re-assign them once they are available.
