probleme solved!
seex
probleme solved!
Post by seex »
Win WP/ SP1
Nvidea 5700
1Gb ram
P4 2.8
resolume 2.3
Problem
-All Files dont load when drag and drop
-All Files dont show the preview in the browser
-Decks will load only previews and wont load into chanells
Solution:
A fresh instal of the graphic drivers.
When i was experiencing the problems above, i tryed to switch the output screen on and off, resulume was so qick to do that, that i suspect it was not changing anything. The usual "blackout" that glichy break that happens to the interface when the output screen is enabled just didnt happen.
