I was wondering if the dmx Input device has to be an artnet device, or if it could be done via a USB dongle
Thanks,
Wessel
DMX input device. Artnet node or USB dongle?
Re: DMX input device. Artnet node or USB dongle?
Resolume Arena 6 and 7 only support Art-net. USB DMX devices are no longer supported.
If you need 3/5 wire DMX, there are some Art-net to DMX converter boxes that could work for you.
Can I use two artnet devices? One is my PC running resolume, it's connected directly to the console. And the artnet node goes to the stage.
Can I use a ethernet switch or do I have to get a pcie Ethernet card?
Art-net works over regular Ethernet, so you can just connect your Resolume machine to your existing Art-net network. Make sure to use the same IP address range than the other devices and nodes.
These support articles should help with the input and output settings in Resolume:
https://resolume.com/support/en/dmx-shortcuts
