Arena 6 Project: Most Columns Missing in Arena 7
nightjar84
Post by nightjar84 »
Hi there,
I upgraded to Arena 7 and just opened a project I created in Arena 6, though only the first 9 columns are there and not the rest? How can this be solved or is this a known bug?
Thanks and cheers
nightjar84
Re: Arena 6 Project: Most Columns Missing in Arena 7
First the project file is 1.7 MB (from Arena 6)....when I open it in Arena 7 it suddently is only 900kb large...so Arena deletes the columns?
We're working on this, though we know of this happening with Resolume 5 compositions.
Got broken in 7.0.4, opening the composition in 7.0.3 should work meanwhile.
You can save the composition in 7.0.3, go back to 7.0.4 and it should have all the columns.
You can get 7.0.3 from the bottom of our download page.
If you're sure this happens with a composition created in V6, please send the composition to us to mail@resolume.com
nightjar84
Thanks for the support. I confirm: Version 7.03 works!
Which file you want? Before or after corruption?
The original one, that has all the columns.
