Few questions about resolume 7 (midi - clip target ...)
Timoxy
Post by Timoxy »
Hi All,
I've few questions about the midi and the clip target.
Midi :
How it's possible to attribute 2 notes midi for one option ?
I explain : For exemple the composition speed i want use the tempo rotation button on my akai APC 40 mk2. and i want use the nudge + to reset the value at 1. But i can use only one button on this value.
Clip target
Sometime i use resolume not for vjing but for play few videos for volleyball match for exemple. For this i use Clip target => Active Layer.
I use few layer (7) and 14 columns.
Layer 1 : advertising
Layer 2 : sponsors
Layer 3 : Marketing
Layer 4 : Goodies
Layer 5 : PLayers
Layer 6 : action match
Layer 7 : Cameras
The layers 1,2,3,4,5 work in autopilot the rest i've the hand.
But i don't found the good procces to work like this :
i click on the layer 1 column 1, resolume go to the next vidéo automatically
When i clik on the layer 2 column 1, the vidéo is play but go automatically on the layer 1 column 2, and play automatically the layer 1.
is not possible to make this ? :
i clik on the layer 1 column 1, the layer 1 play automatically
or, when i clik on the layer 2 column 1, the layer 2 play automatically. Same thing for the layer 3 and 4.
All is ok for me in resolume but this no ....
Thanks in advance.
Re: Few questions about resolume 7 (midi - clip target ...)
Timoxy wrote: Fri Nov 15, 2019 18:08 How it's possible to attribute 2 notes midi for one option ?
This should help: https://resolume.com/support/en/midi-sh ... -shortcuts
Timoxy wrote: Fri Nov 15, 2019 18:08 Sometime i use resolume not for vjing but for play few videos for volleyball match for exemple. For this i use Clip target => Active Layer.
Shortcut Targets are for shortcuts: https://resolume.com/support/en/midi-sh ... cut-target
If you use mouse clicks, or auto pilot, the Shortcuts are not used.
