Audio Clip
franchess44
Audio Clip
Post by franchess44 »
Dear all,
With Arena 5, there are "composition window", "Layer window" and "Clip window", normally in each windows there is an audio controler but i removed this part in the "Clip window" and i don't know how find the audio controler now... Could you give me some help please ;)
Thx
Re: Audio Clip
If it's only missing from the clip panel, I think you might have removed the audio track from the clip.
If that's the case, you can add the audio track back to the clip, by dropping the file to the clip panel.
If the Layers have only the Video slider, then you probably disabled Show Audio controls in the View menu.
Re-enable it, and your layers and clips with audio will get the audio controls back.
