atm I have to decide between the following options, can some fingerpoint the best solution for a 8 FHD output setup (at least 4 Outputs Framesynced). For some Inputs the BMD Card is added.
- HP Z8 G4
+ 2x Intel Xeon 4114 (10x 2,2 GHz)
+ 64 GB ECC reg. RAM
+ 512 GB Z-Drive
+ 1x Nvidia Quadro P2000
+ 2x GeForce RTX 2080 Ti
+ Blackmagic Design DeckLink Duo 2
+ 4x 8 TB SATA HDD - HP Z8 G4
+ 2x Intel Xeon 5118 (12 x 2,3 GHz)
+ 512 GB Z-Drive
+ 2x Nvidia Quadro RTX4000
+ 1x Quadro Sync II Card
+ 1x 1 TB SATA SSD - Custom Build by Supplier
+ 1x Intel Xeon W-2145(8 x 3,7 GHz)
+ 256 GB PCIe M.2 SSD
+ 2x Nvidia Quadro P4000
+ 1x 960 GB PCIe M.2 SSD
The decesion has to be made on monday
PS: Also some other Software will be used on the WS, for example Davinci Resolve, MadMapper, Adobe Premiere/After Effects, so a good overall solution would be great.
