Resolume 6 auto increase the speed of clip when play
kevin
Post by kevin »
Dear all,
I have problem with Resolume Arena 6, the symptom is: when i played the clip (play column), all the clip in this column and other run very fast although the speed still is default. After that i restart the server, it gone and run normal but i want find what is the problem and how to fix it because i scare it will happen in the future and very dangerous when I run the show.
Many thanks,
Re: Resolume 6 auto increase the speed of clip when play
I'd recommend checking the composition speed first, in the composition panel.
It's quite easy to nudge it accidentally on the UI without noticing.
If you have any shortcuts mapped to it, check those too.
If you use any other audio apps, make sure they are set to the same Audio sample rate as Resolume.
