Creating a Custom Resolume DMX profile
im new to Resolume and i was able to send signal to my LED Pixel strips but now im trying to go through Jands Vista 3 and i believe i have to create a custom profile and just need help on where to begin
Re: Creating a Custom Resolume DMX profile
Resolume can output dmx and can recive dmx... the input dmx map is saved in a folder in the preferences..just in case you ll need this later...
For Output:
You drop a fixture on the video inside the advanced output. For special lighning stuff you ll need to build your own fixture... you can set inside the fixture how many channels there are (rgb/w/a/uv/....) and were they are and what they do (simply spoken)....
this fixture editor is also inside the advanced output menu....
is that what you need?
For Output:
~Berlin~
~Berlin~
