s-video flickering
bsom_
sometimes, when i right-click on buttons in resolume to select mixing preferences, for instance, my full screen extended desktop s-video output from my laptop starts to flicker horribly. the only fix is for me to click "dual monitor" button to remove the output from the 2nd screen, then click it again, then resize the window on the 2nd screen. this would be bad, very bad, since i have up-coming shows which I'm going to use resolume for... when is the next version coming out? perhaps that will fix my problem?
malden_
bsom_
this isn't a mild flickering that could be adjusted...
it looks like an old TV with no vertical hold. it literally makes the image projector unviewable, since it just looks like large black and white bars in a rolling pattern...
i guess it doesn't matter, anyway. i'm just about to order a new laptop, so hopefully the problem with stay with the old one...
at what resolution have you set the output window. If you use video out it happens that you can't use a resolution of 320x240 if you want to go fullscreen. That's because a s-video signal has to be higher then 320x240. Try setting the output to stretch to 640x480. So the resolution will be 640x480 but the calculation will be done in 320x240.
If this doesn't help try the following, right click the output screen and choose Full frames only. Play with this option to see wether this helps..
Let me know if it doesn't
Cheers
Cheers
bsom_
