Resolume Arena 4 Crashes randomly
MThorrez
Post by MThorrez »
Hi there, we have a problem with a resolume arena 4 project.
I added the logfile here:
http://users.skynet.be/moartn/ResolumeArena4log.txt
Maybe someone can help us out with it?
The project crashes randomly, not when hitting certain clips, but it always crashes at some point.
In the logfile there's a lot of "No Samples buffered when trying to get audio", so I think it has to do something with audio? I changed the buffer size, but without any results ..
All clips in the project are converted to the dxv3 codec.
Audio is set to 44.1 KHz in the main settings. Most of the clips are 44.1, but some clips are 48, can this be the problem?
Re: Resolume Arena 4 Crashes randomly
Are you maybe running out of memory?
MThorrez
Post by MThorrez »
Zoltán wrote: Thu Jan 23, 2020 12:11 Are you maybe running out of memory?
No, I checked using the activity view ..
I have 16 GB and max 1,2 GB is used when running the project ..
Do you have any jpegs, pngs or other still images in the composition?
How many clips are in your deck?
