Composition glitches in A7 but not in A6
Han
Post by Han »
I have a problem with glitches in A7.
These glitches are appearing in the output window and in the physical outputs.
It looks a little bit like a v sync fail.
The thing this, when I open the same composition in A6, it works perfect and there are no glitches.
Specs:
i7 -7700
1050ti
16GB RAM
All Clips are DXV and are saved on an ssd.
Anybody with the same problem or a good solution out there?
Re: Composition glitches in A7 but not in A6
What kind of glitches, do you have a screenshot or video so we could have a better idea?
Is vsync on for Resolume 7 in the nvidia 3d settings?
Han
Post by Han »
I uploaded 3 videos.
https://drive.google.com/open?id=1guGg5 ... zRQSzw1n6z
I tried it with and without v sync. Unfortunately nothing changed.
Menno
Post by Menno »
It may be worth comparing nvidia profiles between v6 and v7. Any changes you've made to the v6 profile that may have solved this previously will not have been moved over to the v7 profile so you need to make them again there.
Han wrote: Sun Feb 09, 2020 12:38 I tried it with and without v sync. Unfortunately nothing changed.
Have you restarted Resolume 7 after changing the setting?
Is Resolume 7 still in it's original program folder?
