Min + Max Parameter Controll
Avitvideo
Post by Avitvideo »
It would be good to be able to assign the min and max values for bpm synched parameters to midi.
Please...
He2neg
Re: Min + Max Parameter Controll
Post by He2neg »
Can you post a screenshot of the value you want to limit ( open) ?
If you set a value with a fader you can see small little arrows on max& min these can be used to limit the area like you want...
As well you can set a range inside the midi mapping menu
you find some more information inside the manuall:
https://resolume.com/support/en/midi-shortcuts
~Berlin~
Avitvideo
Post by Avitvideo »
I'll post a screenshot later but in text: it's the small little arrows on max& min that I want to controll via midi when using bpm synch.
One example us is that I have a vertical blur set to bpm synch and I want to turn the upper limit up and down using a rotary, I don't think I can do this currently, am I missing something?
Thanks,
Can you use an envelope?
Avitvideo
Post by Avitvideo »
Thanks guys,
I can't see a way to increase the max triangle slider thingy using the envilope, here is an image of what I would like to control
Meirion
#13797 in the features bucket ;)
Avitvideo
Post by Avitvideo »
Cool!
himatchi
Post by himatchi »
I need this feature too!
I can't wait to be able to use it.
