audio input
Corner
audio input
Post by Corner »
Narf another
would be quite cool if you could start a file over and over again automaticly to high middle or low audioinput
I dont know if this understandeable...
cheers to ya all
continuity-B
Post by continuity-B »
I suggested this a while ago I think as 'trigger on the beat'
When the level of the selected channel crossed a defined threshold it would re-trigger the clip each time.
Anonymous
Post by Anonymous »
this feature is possible with res2.3? i'm searching for this too
and another useful feature for me would be to set cue-points in the clip where the clip will be continue with playing after a trigger occurred (trigger via audio-analysis or midi)
but at all, resolume rockz :)
