Shaper effect and source
Starkiller
hi. I'm trying to figure out what the shaper effect does. But I can't seem to figure it out. What does the effect do and what is the difference between the Shaper in the effect menu and the Shaper in the Sources menu?
Re: Shaper effect and source
The Shaper in the Sources panel is a source where the video source is the shape generator.
With the Effect version, you can use the Shapes mixed to the original texture of a clip, layer or the composition.
