I am in a hurry, I only find GPU´s with 4 outputs, like Nvidia RTX 2080 Ti.
Does anybody knows which GPU has up to 6 outputs (mentioned in https://resolume.com/support/en/lots-of-outputs), and works smooth with Resolume?.
Thank you in advance.
Which GPU has 6 outputs that works with Resolume?
Re: Which GPU has 6 outputs that works with Resolume?
Old AMD Card can but the way to have more than 4 output on 1 Card are cutting UHD signal to 4 FHD (if you don't need 6x UHD) (Nvidia série RTX 2xxx can up to resolution 8k max or 4x 4k)
With:
- Datapath FX4
- Matrox QuadHead2Go
- Gofanco Prophecy 4K HDMI 2x2 Video Wall
Or others
With:
- Datapath FX4
Or others
Asrock X5700XT has 6 outputs and suports 6 displays. It is a modern GPU with descent perfomance
http://www.asrock.com/Graphics-Card/AMD ... cification
You can find Aorus Nvidia cards with 6 to 7 outputs, but 4 simultaneous displays only. This cards are good to connect dual link 8k monitors. So be aware.
Thank you for your responses
