Default playmode
He2neg
Default playmode
Post by He2neg »
hey Folks,
On my System the default playmode i set is not working as expected. The clips i drop in are allways running in loop mode but i set the default to play once and hold.
I did restart Resolum. In the preferences the playmode is set correctly and dont reset the value, but the clips just all start with looping playmode.
I also did rename the arena folder in the documents so resolume need to set all new but it still wont apply the default play mode to the clips.
Did i miss something were i need to set something as well or is it a bug in the moment.
Version 7.1.0 rev 67353
Thanks for reply
~Berlin~
Re: Default playmode
issue #13521
Will be fixed in the next release ;)
