Connecting to Chauvet Epic 900 drive
Kristismith
Hey has anyone used Resolume to control Chauvet's Epix strips or bars? I have a demo of the 900 drive and a epix tour bar. The drive doesn't show up in the advanced settings and I've tried the target IP address but nothing.
Re: Connecting to Chauvet Epic 900 drive
Did you select the DMX network interface in the Resolume preferences? https://resolume.com/support/en/dmx#pic ... -interface
boris.lema
i do from time to time, it works great! The company that i work for during summer uses resolume only for epix strips because its easier to map and configure the strips.
Are your drivers set to Art-Net? You use the Ethernet out of your pc or first go to a switch, than to the drivers. Your PC ip should be in the same IP range of you driver. I know there is a startup/connection time. Sometimes they pop up in seconds and sometimes you need to wait a minute untill they pop up....
