Even when re-installing avenue, it crashes with macbook 2019 16" catalina 10.15.3 (19D76)
Anybody has the same issue ?
best
SYPHON CRASH CATALINA 10.15.3 (19D76)
Audio-reactive Led designer
https://visualsystem.org/
https://fr.linkedin.com/in/pierre-gufflet-07803697
Re: SYPHON CRASH CATALINA 10.15.3 (19D76)
Can you please use the crash reporter dialog that pops up after the crash to submit a crash report?
https://resolume.com/support/en/reporti ... rt-a-crash
Don't forget to fill out your email address, so we know it came from you
Thanks for all your support I received by mail.
The solution was :
i couldn't say precisely which virtual camera driver was making the problem,
but i desinstalled (using app cleaner!)
Iglasses
Camtwist
IP camera viewer
Webcamoid
it works perfectly now.
Thanks resolume for your reactivity
The solution was :
Iglasses
Camtwist
IP camera viewer
Webcamoid
I think it was iGlasses.
