Hi!
potential new user. is there any way to stream an input to resolume over the web? I'm imagining having someone output a stream through OBS to take as an input?
thank you!
stream input over web?
Re: stream input over web?
NDI Scan converter could grab the playback of the stream, and you can then use the NDI source in Resolume: https://resolume.com/support/en/NDI_inputs_and_outputs
We just wrote an article that shows you how to stream Resolume using OBS: https://resolume.com/support/en/Streaming
