Good day,
I have a strange issue where I have an image that I used in the composition, but now it shows up in the background of EVERY thing I do in the same comp.
I can change decks and the image is still being shown in the background. Mind you it is in black and white and it is like changing the image or video that I put up. I hope this makes sense.
I am sure it is something happening to the bottom row, of everything in the composition. if I move the items up an row they are fine but this image (that I have deleted) is still showing when ever something is on the row.
Dave
image is showing up that isnt selected.
Re: image is showing up that isnt selected.
I deleted the entire layer (row) in the deck and it is gone. I just found it strange it was doing the same thing in other decks.
thanks
thanks
If you play a clip in a layer, you can switch decks, the layer will still play the clip you started until you launch another one or clear the layer.
If the image was an overlay on the content, in the layer, then I'd guess it was placed as a mask onto the layer. https://resolume.com/support/en/effects#mask
