Now that resolume 7 is installed and working, pretty much, a new problem has arisen. As long as I was using it everything seemed fine. But if I let it idle for a little I'd get the blue screen of death and it would reboot. I'd launch it again and repeat. I am wondering if anyone has heard of this happening before?
Thank you gize for your time!
Rick
reboots
Re: reboots
Check your power settings. Sounds like hard drive going to sleep.
Re: reboots
If I change the power settings do I have to restart the computer for the changes to take effect?
