Live Input (capture card) audio input
lamatastisch
Post by lamatastisch »
I have a BM Atem mini pro connected via usb c to my pc with resolume arena 6.1.5. I want to output the video with the embedded audio. How is this possible? Any ideas?
I see the audioinput in fft Audio
Re: Live Input (capture card) audio input
Do you see the BMD in the Audio output device list?
https://resolume.com/support/en/prefere ... references
lamatastisch
Yes.
My signal flow: Cameras -> BMD -> Resolume -> TV
-> Resolume Recording
Ok, read your post again, so, you'd like to get the Audio from the capture into Resolume, and not send the audio to the BMD output, right?
Audio inputs from capture cards is not supported currently, I'm afraid.
lamatastisch
Zoltán wrote: Wed Sep 09, 2020 08:33 Ok, read your post again, so, you'd like to get the Audio from the capture into Resolume, and not send the audio to the BMD output, right?
Yes exactly.
Ok, would be a nice feature for upcoming versions!
lamatastisch wrote: Wed Sep 09, 2020 09:47 Ok, would be a nice feature for upcoming versions!
Yes it would.
You can vote it up here viewtopic.php?f=6&t=11027
