window / screen capture
visions
Post by visions »
Window / Screen / appplication area cpture.
I use this funcion in obs or vmix, and I send to Resolume using NDI. But NDI has some delay and high CPU usage. In there any plans to integrate this function in resolume in any time soon?
Re: window / screen capture
NDI scan converter could be a faster one than OBS.
Would love this too, but I can also see this being a grey area, You would probably have to jump through some hoops to keep companies like Netflix and Youtube happy for their legal clauses against pirating.
For OSX users Syphoner:
http://www.sigmasix.ch/syphoner/
is an amazing tool! For Win users, as @Zoltan has already said, NDI Scan converter is the way to go. Be sure you have a loopback adapter installed on your machine, otherwise if you are running a show somewhere with no active network connection, NDI will drop out. Also, the older version of NDI Scan Converter is still miles better than the new one.
Here's a link to a copy:
https://drive.google.com/open?id=1Ao3lL ... p=drive_fs
Otherwise you'll need to ask for Newteks FTP site to get it.
Aboudeh
Post by Aboudeh »
what about the sound signal how can i have it direct to resolume without using any other interface ?
Aboudeh wrote: Fri Oct 02, 2020 11:24 what about the sound signal how can i have it direct to resolume without using any other interface ?
We have another feature request for that here viewtopic.php?f=6&t=18485
SloppyButDecent
Post by SloppyButDecent »
Not to revive an old post here but I was checking up to see if this had moved anywhere recently.
Arvol wrote: Wed Sep 16, 2020 15:08 Would love this too, but I can also see this being a grey area, You would probably have to jump through some hoops to keep companies like Netflix and Youtube happy for their legal clauses against pirating.
Millumin has the functionality to use your local machine’s desktop as a live input. Additionally, you can choose a specific App you’d like to use, regardless of its location on the screen or minimized status (I believe).
I for one would be able to use Resolume on many more corporate shows where I need slicing capabilities but really just need a web browser input.
SloppyButDecent wrote: Tue Sep 12, 2023 17:41 Not to revive an old post here but I was checking up to see if this had moved anywhere recently.
OBS Desktop Capture>Spout Output To Resolume
leadedge
Post by leadedge »
Hey all. Maybe this https://github.com/leadedge/Win32Captur ... /tag/v2.03 might do the job.
_Ineffable_
Post by _Ineffable_ »
Yeah I'm on Mac. Tried using scan converter but on 4K that lags very badly..
Syphoner is discontinued and does not work (on M1) Is there anyone that knows a way to syphon an app window?
Yeah don't worry! I put it on autopilot!
Syphoner works just fine on my M1
