One monitor turned to full screen - cant get back
matt_is_rockin
Post by matt_is_rockin »
I've just started with resolume on my laptop and it appears my built in graphics card can pass out to the VGA port but only a clone of the laptops screen.
I set to full screen mode and now I cant do anything, just a black full screen and i cant get back to the main program.
Does anyone know how to solve this?
Thanks,
Matt
continuity-B
Post by continuity-B »
what exactly is the make and model of the videocard?
matt_is_rockin
Its an S3 Twister, i now know it doesnt support dual output so i'll probably try to get another laptop for the gig but it'd be good to practise on mine if I can get it back to normal mode without reinstalling!
Cheers,
Matt
Anonymous
Post by Anonymous »
try reinstiling your graphic card drivers.
press ALT + CTRL + ENTER to return from fullscreen or delete the file C:\Program Files\Resolume 2.3\settings\screensetup.xml
we are aware of this problem and we are goingt to fix this.
[Edited on 1-11-2005 by bart]
