Resolume and EGPU
Aboudeh
Resolume and EGPU
Post by Aboudeh »
Hey all , i am already buy the Razer core x EGPU for my MacBook pro .
the question is what is the best graphic card using for Resolume arena 7 with this EGPU.
Re: Resolume and EGPU
The best one is the one that fits your budget and gives you the performance you need.
Personally the RTX3070's seem to be a great value for performance.
Aboudeh
Post by Aboudeh »
ok thank you ..
what about amd do you special card compatible with resolume and mac
I have never been a fan of AMD and I know there has been at least twice as many problems using AMD with Resolume in the past (usually driver related). But there are also many people using AMD with Resolume just fine. That's your call. I suggest buying what fits your budget :)
