Arena 5 issues on Mojave
benneill
Post by benneill »
Arena 5 isn't running for me on Mojave 10.14, I have some old projects that need Arena 5 because of plugins that aren't available for 6 and 7. I tried redownloading Arena 5 and installing it, but still doesn't work. Any suggestions?
Re: Arena 5 issues on Mojave
Try renaming the Documents/Resolume Arena 5 folder to check if it's an issue with the settings.
If it doesn't help, please attach the mac crash log, and the Resolume log file from ~/Library/logs/Resolume/
benneill
Post by benneill »
I don't think there is a crash log because the program just doesn't open at all when I double click on the application or try to open a Composition with it.
Mac crash log should be in /Users/yourUser/Library/logs/diagnostic reports
Does the Resolume log file exist in /Users/yourUser/Library/logs/Resolume/ ?
leolodreamland
Post by leolodreamland »
i have this problem too, need to use res 5 for dmx with usb and two universes...
renamed settings folder, reinstalled res 5, res5 log is empty... just won't launch. one bounce and an error message from the system.
____________________
chromatouch visuals
If you're looking to jump into the new Resolume 7, this box is affordable and will get you off the usb dmx path and into artnet:
https://dmxking.com/artnetsacn/edmx2-pro
leolodreamland
Not right now. I do own 6 tho. This works with that?
chromatouch visuals
Yes.
So, what's the error message in the system, and the crash log in the folders I posted earlier?
leolodreamland
It’s empty. Like we both said earlier. It doesn’t even get to a state where it launches to put anything in there.
chromatouch visuals
