Bounce playback not working as expected
dgodd
Post by dgodd »
Hello,
Upon loading a composition, or triggering clips, the bounce playback is now working as if it were on loop instead.
In order to reactivate bounce, I must pause and play the parameter that is animated using bounce.
Version 7.3.0 rev72365
Re: Bounce playback not working as expected
Thanks for letting us know!
I'll create a ticket!
Seems only BPM transport is affected, maybe you can set the param to timeline meanwhile.
dgodd
Post by dgodd »
Thanks Zoltán! And I appreciate the suggestion, will make use of that in the meantime.
Have an awesome day, I appreciate you and the team!
