Ultrawide Monitors
Ultrawide Monitors
Can you use Resolume on an Ultrawide desktop monitor having part of the screen to show the output of the visuals you are creating?
Re: Ultrawide Monitors
You will need to output to spout then use a spout viewer as a "windowed" app you can move around and resize
- gpvillamil
Or just choose "windowed" output in the Output menu, and drag the output wherever you want. If you hover over the lower right corner of the windowed output, you will see a resize cursor pop up.
Arvol wrote: Thu Nov 26, 2020 19:04 You will need to output to spout then use a spout viewer as a "windowed" app you can move around and resize
Not if you're also outputting to a projector or LED wall.gpvillamil wrote: Tue Dec 15, 2020 22:49 Or just choose "windowed" output in the Output menu, and drag the output wherever you want. If you hover over the lower right corner of the windowed output, you will see a resize cursor pop up.
- gpvillamil
Wait, even better option: start from the Big Monitor layout (View/Layout/Big Monitor) and then drag the preview monitor to the left or right edge. You can resize it from there. You can have your clip grid, effects etc off to one side and a full size preview all on your ultra-wide monitor.
