ETC ION and Resolume
fbacc01
Post by fbacc01 »
Hello there,
We just get licence of Arena and its still new to me also as a lighting console ETC ION (i know basics)
What i need to help?
Actually still dont know optimal and easiest way how to do basic dissolve (from solid black 5sec transition to clip (hold) and after trigger 5sec transition to black and again to next clip)
I hope i can try to find solution but dont know if its good way.
I can make a clips in something like davinci resolve with 5s fade in and out but thats stupid...
I think answer for me is this link? https://resolume.com/blog/19719/resolum ... ransitions
But i have more stupid questions...
Maybe i am just greedy but it is possible with one channel on ION concole control more shortcuts? (for example on value 25 trigger column 2, 50 columnt 3...and on zero go back to column 1?) Range doesn't work to me, if u use it right...
Re: ETC ION and Resolume
You can do up to 10 seconds transitions in Resolume, no need to pre-render clip fades ;)
https://resolume.com/support/en/dmx-shortcuts and https://resolume.com/support/en/layers#layer-transition should get you started
If you'd assign a single channel to the Composition or layer's "Clip trigger" item, you could launch 255 clips with just one fader.
