How audio output an FFT input
Celyniel
Post by Celyniel »
Hello,
I have a simple problem.
I have an audio interface connected as an audio input no problem.
I use it to drive my visuals (external FFT input), no problem too.
But I would like to hear the sound in my macbookpro's speakers. It doesn't work.
How can I use the audio input as an audio output in resolume?
Audio from a clip works perfectly, only audio input doesnt output.
Thank you!
Re: How audio output an FFT input
You need to turn on monitoring in your interfaces setup. you also might have to route that monitoring to your speakers as an input using some sort of internal virtual cable.
