I didn't know where to ask so I'm starting here. Basically I have 9 different loop videos with 2 variations each. They will be projected on 3x3 grid. When I send the trigger on OSC, it should play either A or B variations of each clip in squares. It doesn't need to be randomized or anything. I just wanted to know what's they best way to achieve this. I've been thinking of using Advanced output with 9 different slices, but I'm really lost how to put this all together.
Every A variations on Layer 1 and B variations on Layer 2? How do I play all of the clips in Layer 1 at once?
Every A variations on column 1? and B on column 2?
Separate variations by decks? How do I put the clips in grid?
Here is the 2 states, in case if I messed up while trying to explain
Thanks a lot!
